lil nervous because i had none of the problems others were having. i saw update this morning and hit it be for i noticed what it was. thought it was a regular app. i was half sleep. hope i dont get problems now. my chrome stopped working and went all black. turned off then back on and its fine. will see what others say.
The XDA forum says it fixes the camera and battery tracking in the Settings, but "random reboot" (RR) is still ours to love and cherish.
Asus doesn't even acknowledge that there is a issue. How is it possible??
I wasn't having the random reboot problem before the update and am
not having after, either. Also, no issues with the GPS that I can detect,
although I don't use it for anything. If I turn it on, it can see a sat or two
inside the house; haven't had it outside.
I was having the battery drain issue and will check on that as time goes
by.
So far, the update has had no negative impact and I'm not seeing anything
that's improved, either; seems the same as before...
