Root system folder Read write permissions??
Piiman
Android Expert
should the system/apps folder and system/bin folder be R/w or R/O
I'm trying to remove some stuff and can't remember. Help I setting here waiting:o
r/w to remove stuff.
So R/O for normal operation?
By the way if anyone is wondering the one click root/unroot doesn't remove the Superuser.apk or ninja icon.
Ok finally got it.
If anyone is using the one click unroot. You'll have to remove these files manually or you'll still have the Superuser icon in the app drawer.
/system/app/Superuser.apk
/system/bin/su
/system/bin/busybox
finally remove the rootshell
/system/bin/rootshell
And then su superuser.apk and busybox from the root of you sd card (You may not have to do this but when I didn't remove them they seemed to get reinstalled in the system folders. )
reboot
