The only things I've done so far on this device is change boot anim, screen transitions, carrier name, and CRT effect.Font Installer *root* worked great for my 'lil Admire. I'm skeered to try it on here until someone can figure out the restore method. Most likely some good cracker/programmerThe only things I've done so far on this device is change boot anim, screen transitions, carrier name, and CRT effect.
Font installer is what I use and there are a lot of fonts to choose from I usually use Sony sketch too![]()
Download the font that you want and paste the files to /system/fonts.
ROM Toolbox
font installer is what i use too you have to go into setting under display and change it to "roboto" thats the one the program changes to the font you pick at least on the lg motion..just in case some one of the future is reading this and wanted to know![]()
Works great dude thanks. Some fonts didn't change tho do you know how top remedy this?
if i find a way to do it ill make sure to post it so everyone can benefit..Yep.What do you mean by change carrier name? Like you can change the "MetroPCS" into whatever, like to "Spongebob" or whatever.
