ptmarzullo
I know on the Warp under the Task Manager it will show you what apps are running in the background. Is there a spot that will tell you how much RAM/Resources each app is using. I was able to find it once before, although it might of been when I did not know any better and had a task manager that reported them.
Does anyone know how I can accomplish this without having to have a task manager just to see what apps are using what amount of memory?
Please help. As always, all you help is greatly appreciated.
