Help System settings are gone?
JDML
Yeah after a Titanium Restore they are gone, no more playstore, can't get into settings to do a restore, nothing, no task bar....ugh, anybody have any suggestions?
This belongs in root section.
If you have cwm installed you can download the latest jb Google apps package, http://click.xda-developers.com/api...6-signed.zip&jsonp=vglnk_jsonp_13806229796056
As for settings.... I can try to copy my settings apk and odex file and put it on my dropbox you'll have to use a root explorer (will also pack es file explorer with it for you) to put it where it goes though.
https://db.tt/lMDfFmIT
Hope this helps.
You'll need to unzip the dropbox file as I can't upload uncompressed folders
