LakersDroid
Android Expert
I just got notified of a system update available. It says it's an update to Ice Cream Sandwich. The file is 14.65 MB in size. Should I go and update?
If you want the fixes for the phone (mms and rfx problems) yes,
If you like the way works, don't
Why didn't they mention anything about it being an update to fix the mms rfx problems and the radio errors? The pop up just says it's an update to the 4.03 (Ice Cream Sandwich) that would improve it.
Its the radio update. I actually have it on my drop box...But go ahead and take the OTA.Trust meIts the radio update. I actually have it on my drop box...But go ahead and take the OTA.
Okay, are there any other benefits from installing this update beside the radio interference errors fix?
Are you absolutely sure? I received an update notification around the time they released the fix, but I ignored it because I'd already fixed it following the guide from the forum. I haven't received any other notification until this week. I thought I remembered that notification mentioning the fix, while this one doesn't. I could be wrong.Trust meIts the radio update. I actually have it on my drop box...But go ahead and take the OTA.
Are you rooted / s-off?I decided to update last night. It went smoothly. A couple restarts and my phone was back up running showing latest software version 1.14.652.0 710RD and radio baseband 1.09.00.0706.![]()
I posted a screenshot of the update here.
And as asked earlier in the thread, is there any other benefit to the update other than the signal fix?
