sheyenne56
solution !!!!
Root your phone>install rom manager>open rom manager>go to fix permissions>start fix permissions > and the problem is solved
applause for me![]()
thx alot I<3U
solution !!!!
i need help too. ugh. lol
Solution !!!!
My bf bought me a Nexus 4 so I was trying to reformat my Incredible to give to my sons and I didn't think to unroot first. I kept getting the "inconsistent UIDs" error so I followed your suggestion and it worked, thank you so much!Are you rooted? If so go to recovery - advanced and select fix permissions. If your luck it will fix it, if not a factory reset, fresh install, or nandroid restore is required.
Solution !!!!
