Root System Update Not Installing (rooted)
maplewood
My Incredible is rooted. For the past few days I've received a notification that a system update will be installed and the phone will reboot.
Nothing happens, no reboot and no evident change.
Now that the phone is rooted do I need to apply updates manually? Should I take the Verizon updates at all? (The only specific change mentioned in (more info" for this update is the addition of an app called "Slacker")>
Bob,
Thanks for those great and detailed instructions. Sorry to be so dense but could you please provide instructions | menuing path for these preparatory steps:
1. Tasker -> Off
2. System Monitor -> Monitoring Enabled -> Off
3. AutoMemoryManager -> Default
4. SetCPU -> Profiles -> Enable -> Off
5. WidgetLocker -> Settings -> Enabled -> Off
I think those are just apps, maplewood. Some of them may send instructions that could potentially cause problems during the root-update process. He means, if they're installed in the custom ROM, go ahead and disable them.
Mind, I haven't rooted my phone, so I have no first hand experience with any of this - just a rather lame intellectual interest :). My understanding is -
BD's instructions (Installing OTA to Rooted Android) allow you to update and RETAIN root.
You can also downgrade to OFFICIAL 2.2 (http://androidforums.com/incredible-all-things-root/181255-how-downgrade-official-2-2-a.html) and then get the update normally. The latest Verizon OTA broke the Unrevoked rooting method, and I don't think they've released their new version yet, so you'll have to wait for that before re-rooting.
There's also a way to disable the annoying 'update me!' message and just stick with what you have if you prefer (though obviously you'd miss out on the update) - http://androidforums.com/incredible-all-things-root/217209-got-rid-ota-update-nag.html
-HD
