system update
Here's some info in an email that I got about it:
"Software update: HTC One S"
To view the document, visit: http://support.t-mobile.com/docs/DOC-4262
1. Understanding the Update
Beginning *December 10*, the HTC One S devices that are on currently outdated software (1.53.531.16 or 1.84.531.2) will start receiving an update to software 2.35.531.10. It will be pushed to devices though an OTA through the end of December, or you can choose to download it earlier.
*Important:* Both 2.35.531.10 and 2.35.531.7 are up-to-date versions. If you have one of these two versions, you cannot update further as there would not be additional benefit.
You can update in two ways:
* *Over the air (OTA) update:* T-Mobile will push the update to your device sometime between 12/10 and 12/30. We cannot expedite this push to your device.
* *Manual pull down:* If you do not want to wait for the OTA, you can update immediately through the settings menu. See the steps for Download update from HTC below.
|| *Current Software Number* || *Update Status* ||
| 2.35.531.10 710RD
2.35.531.7 710RD | Both software versions are current. Your device software is up to date. |
| 1.84.531.2 710RD
1.53.531.16 710RD | Beginning *September 26*, follow the steps below to *Download update from HTC*. |
| Other versions | T-Mobile and HTC will +not+ send you a software update.
Devices with non-T-Mobile software versions are out of warranty and do +not+ receive updates. |
h5. Software versions
See also: http://support.t-mobile.com/docs/DOC-4276#Software_version Check your software version.
* Android version 4.0.4 / Software number 2.35.531.7 710RD and 2.35.531.10 710RD - *Current version
**Version*
* Android version 4.0.4 / Software number 2.35.531.7 710RD and 2.35.531.10. 710RD
* Updated 9/26/2012 and 12/12/2012
*Improvements** Update from Android 4.0.3 to 4.0.4
* Helps with data connection delay (http://support.t-mobile.com/docs/DOC-4288)
* Helps with signal fluctuations (http://support.t-mobile.com/docs/DOC-4436)
* Helps with Wi-Fi dropping connection or not connecting (http://support.t-mobile.com/docs/DOC-4624)
* Helps with Wi-Fi stays connected when out of range (http://support.t-mobile.com/docs/DOC-4507)
* Helps with device crashes or restarts (http://support.t-mobile.com/docs/DOC-4505)
* Helps with email links do not open (http://support.t-mobile.com/docs/DOC-4911)
* Helps with loading screens or lag when returning to home screen (http://support.t-mobile.com/docs/DOC-4912)
* Helps with streaming music skips (http://support.t-mobile.com/docs/DOC-4542)
* Improved Wi-Fi stability
* User interface improvements
* Improvements to Bluetooth connectivity
* Improvements to prevent devices from getting permanently stuck on 2G when updating.
*Note:* If devices are already stuck on 2G, the software update will not fix it. Contact us (http://www.t-mobile.com/Contact.aspx).
*Prerequisites** OTA update
* Device is running Android version 4.0.3 / Software number 1.53.531.76 710RD or 1.84.531.2 710RD
* Device software is not rooted
* More than 50% battery life
* Data connection
* 140 MB available memory (File size of update is 140 MB)
* Android version 4.0.3 / Software number 1.84.531.2 710RD
* Android version 4.0.3 / Software number 1.53.531.16 710RD
So jealous (I'm on TMOUS). I don't know why it is taking so long for Jelly Bean to come to the TMo HOS. I think it is Nexus only for me from now on.
