I really love my Note 2014, but one thing that irks me is that the system volume is LOUD!
Even at low settings (I have mine only 2 detents up from silent on the slider) the system sounds are much louder than I would have expected.
I realise that I could simply switch the slider to silent, but I quite like the Galaxy "plop" sound. I have it on my S3 and there the system volume is nice and quiet and unobtrusive at a minimal detent, but still audible. But on the Note it is much louder than I think that it ought to be. My impression is that the slider appears to go from 100% at max to approx 50% at one detent above silent, then drops off only when you switch to silent. That has to be wrong???
I do also realise that the speakers on the Note are bigger than on the S3, but that shouldn't make a difference.
Has anyone experienced the same? Might this be resolved in the MJ6 (or MK1) update?
Even at low settings (I have mine only 2 detents up from silent on the slider) the system sounds are much louder than I would have expected.I realise that I could simply switch the slider to silent, but I quite like the Galaxy "plop" sound. I have it on my S3 and there the system volume is nice and quiet and unobtrusive at a minimal detent, but still audible. But on the Note it is much louder than I think that it ought to be. My impression is that the slider appears to go from 100% at max to approx 50% at one detent above silent, then drops off only when you switch to silent. That has to be wrong???
