Root [T-Mobile] Attempted to install Beanstalk custom firmware with Gapps and it didn't work.. How do I proceed..
podgemk
Tried to install beanstalk to my S4 SGH-M919 following this tutorial.
http://www.teamandroid.com/2015/01/...oid-5-0-lollipop-beanstalk-custom-firmware/1/
I used Odin 3.07 to install clockworkmod (T_CWM_6.0.4.4_TMo) and then used that to install BeanStalk-5.0005-20141229-jfltetmo and gapps-kk-20140105-signed from my sd card.
I did a factory reset, wiped the cache partition and wiped dalvik cache according to the tutorial.
I rebooted and after a while of watching the beanstalk boot animation I got an error saying either the install wizard had failed or stopped working or "System UI has stopped"..
I had backed up using CWM but when I tried to restore I get an MD5 mismatch error.
So now I'm stuck..
Any help would be greatly appreciated. I don't want to go and do anything to permanently brick my phone so your advice would be really helpful.
The setup Wizard is part of your gapps so make sure you're using the correct ones for your Android version.
Also if your backup md5 is mismatching, go to backup and restore (in CWM) , advanced (or misc) settings and uncheck md5 check and see if that works.
Good luck
I have since installed a different ROM (Echoe 6.1) and it works fine thank god. Should I do a backup now on CWM or would that cause more problems?
