Root [T-Mobile] Can I root my S4 without a PC
joe1379
I had a question can i Root my S4 without a PC? Or can I flash a Zipped file of KitKat? If I can where can I obtain it? I Soft Brick my phone and I can't Odin Flash The Firmware because of no PC or Laptop .
No i'm sorry... ATM you can only use a pc to run the root exploit... If your not rooted you can't flash/install a rom so no for that question... you will need a pc to get it back to stock.. As for a fix to your problem you have to have a pc...
Dobt listen to tyese guys i rooted my m919 s4 with towelroot http://towelroot.com/ you must be on stock v4.3 non rooted to work, if you are on v4.4.4 you can flash cf auto root search it then put your model at the end on google and use odin to flash itll install a cwm and root your phone reallly easy
