Root [T-Mobile] Clockworkmod Recovery not saving APNs!
H4X0R46
Hello guys! Quick question here, Am I the only one who gets frustrated with clockworkmod recovery? Every time I make a backup of a kitkat ROM, it doesn't save the APNs, so when I restore to it, I have no APNs and NO SERVICE! Does anybody know a work around? A setting? Another version of clockworkmod I need to flash? TWRP? Thanks guy! :confused:
Apn backup and restore
Instlation instructions [verified working on jellybean]
Set as system app in titanium
Run, error non ics detected, hit menu, disable ics check.
Close with back button
Run
Good to go, backup apn settings.
Then when u restore ur backup which will include apn backup and restore you can just restore your apn settings.
Somebody test this on kit kat.
