Root [T-Mobile] CM11 KitKat 4.4.2
cocokasper
I just want to say if anyone is looking for a light and responsive rom. this is it.
now the optical, and proximity sensors don't work. wifi calling doesn't work. and because it's not touchwiz the stock GS4 samsung apps wont work.
but if you can do without those and want the fastest most lag free OS...
check it out..
install the zip from SD with CWM
then install the 4.4 (ONLY) Gapps
any other Gapps wont work.
I'm running it with Nova launcher prime
and it's the fastest ROM I've ever seen.
no more of that android lag that all droids have.
After I put custom Icons, Nova Launcher prime, and "missed it" unread counter
these are the stock Icons for 4.4
It's very light on Ram
This is before I installed Nova Launcher. This is CM11
Phone info
Flashing the rom will most likely not upgrade the Modem to MK2? Right?
I have been trying to find a way to do that because I never really updated to the official 4.3 and my phone is still knox free!
i'm unsure since before I used 4.4 I flashed 4.3 with knox... (that super user is blocking)
and to get 4.3 working right i needed to flash MK2...
so from 4.2 without knox... I'm unsure if going to 4.4 will require the MK2, or if it will flash...
maybe a question to ask Jamison over on the infamous developers site.
