Root [T-Mobile] i need help
MrsCrenshaw
So i have a note 2 10gb i think or 12 or something idk
but most of the space that i haven't used in pictures is used up in apps i dont want use or need on my phone. Apps that came pre i stalled on my phone.. I've uninstalled them to their default versions but is there a way to remove them? I take a lot of pictures and i need all my space
Hi and welcome to the forums! :)
There is no way to uninstall the apps which came pre installed unless you root the phone, and that is probably unnecessary. Have you considered buying a micro SD card to expand your available storage. They can't be easily used for apps but are ideal for storing photos. Camera apps can be set to save to SD card by default (its called ExtSdCard or external storage) and you can get them in 4, 8, 16, 32, 64 and 128 Gb sizes. (Price increases with size)
Once again, welcome, and don't hesitate to ask again for more info.
Roger
Thank you, I guess that is the most sensible thing to do huh?
What is rooting your phone? What does that do, I'm curious
