Root [T-Mobile] M7 no OS - HELP please
ubuntu@ubuntu:~/Downloads/sdk-tools$ sudo ./adb-linux devices
* daemon not running. starting it now on port 5037 *
* daemon started successfully *
List of devices attached
ubuntu@ubuntu:~/Downloads/sdk-tools$ sudo ./adb-linux sideload ViperOne_7.0.2.zip
loading: 'ViperOne_7.0.2.zip'
error: device not found
Yeah. I saw it not respond to the devices command but expected that to sometimes happen.
And adb sideload is on in TWRP, you can see that on the phone screen?
Yes it is on, and the thinking bar is moving.
Would installing the OS on my hard drive have any impact?
Nope, no impact, I've done this too many times to count just the way you're set up.
Can you move the cable to another usb port? We definitely don't want it in a USB 3 port.
I trust the cable because it has identified the Android phone in the left panel.
If that fails, reboot the phone into TWRP again, give it another try.
If it's still failing, we can update TWRP -
http://techerrata.com/file/twrp2/m7/openrecovery-twrp-2.8.4.0-m7.img
I already tested that link.
After downloading with Firefox, do -
cd ..
mv openr* sdk-tools
cd sdk-tools
Power down phone. Power on while holding volume down key.
Screen on phone should say FASTBOOT USB - stop if it doesn't.
Back to the command window -
sudo ./fastboot-linux flash recovery openrecovery-twrp-2.8.4.0-m7.img
Reboot into TWRP, adb sideload on, repeat the sudo adb-linux sideload command as before.
Yeah, I feel for you on that. :(
The updated TWRP does the adb sideload operation a bit differently under the hood than your current version.
While you're waiting on the download, go ahead and get through the hassle of putting the phone in FASTBOOT USB mode.
After that and after the download completes, remember to run the three commands beginning with "cd .." - you can copy and paste all three at once into the command window.
ubuntu@ubuntu:~/Downloads/sdk-tools$ cd ..
ubuntu@ubuntu:~/Downloads$ mv openr* sdk-tools
ubuntu@ubuntu:~/Downloads$ cd sdk-tools
ubuntu@ubuntu:~/Downloads/sdk-tools$ sudo ./fastboot-linux flash revovery openrecovery-twrp-2.8.4.0-m7.img
sending 'revovery' (11994 KB)...
OKAY [ 1.867s]
writing 'revovery'...
(bootloader) signature checking...
FAILED (remote: signature verify fail)
finished. total time: 2.924s
ok, what did I break?
mv: cannot stat ‘openr*’: No such file or directory
The move (mv) was right the first time.
It's saying that the file is corrupted.
Get back to the sdk-tools folder -
cd sdk-tools
Now say -
md5sum openr*
You should get the value shown -
Yes. got that value
ubuntu@ubuntu:~/Downloads/sdk-tools$ md5sum openr*
1060cbe5131edb0cc6c235a6d488721e openrecovery-twrp-2.8.4.0-m7.img
ubuntu@ubuntu:~/Downloads/sdk-tools$ sudo ./fastboot-linux flash recovery openrecovery-twrp-2.8.4.0-m7.img
sending 'recovery' (11994 KB)...
OKAY [ 1.880s]
writing 'recovery'...
OKAY [ 0.826s]
finished. total time: 2.706s
but when I rebooted the device it still says v2.6.0.1
I can't thank you enough....but before I do anything stupid, should i select "Install ViperOne" on the phone.. gives me a couple options... Change Log, Flash Extras, etc
You can always go back and add extra.
Just roll with whatever the defaults are, get it up and running. :)
As soon as it's finished and you've booted - first one will take a while - go back to TWRP and make a nandroid backup.
If the install goes well but it doesn't boot, don't panic - let me know. Sometimes we have to give an s-on model a little push.
Otherwise - congrats on getting it done. :)
OK, lol, with all you've been through, here's what you do if it won't boot up after the install.
Command window -
unzip -j ViperOne_7.0.2.zip boot.img -d .
sudo ./fastboot-linux flash boot boot.img
Note the spacing and the dot at the end of the first line, it means "put it right here."
That way if you have the issue, ask, and I'm gone again for a bit, you won't be stuck waiting.
If your boot up worked after the sideload, ignore this post.
It's just for s-on phones and only when necessary to get normal booting right after a rom flash. It's just as normal to have to do this as not.
If you have Linux buds and you want to get your brag on with them, call the command window a terminal, or, terminal window. :)
Let me know how it's going when you can.
