I downloaded cyanogenmod on my s4 and I just tried to install the new cm11 nightly and now it's bricked it goes to the cyanogenmod boot screen and won't go any further, phrase help me!
Some times with recovery can take a while to load if a little blue line of words cone on top left of screen then you should be fine. I had this panic the offer day. I'm no expert but if nothing working you may have to re flash again. Best wait until someone more knowledgeable comes on to help.
Download lies for drivers and Odin look Odin stock file for build were on will need to flash via Odin unless you had a custom recovery and made a backup
Did you make a backup using recovery at anytime? if you have one just use the button trick go into recovery and restore it. if the trick isn't working keep trying it's a bitch to get sometimes.
