Dunard
I having a problem getting the ROOT install on this version. I had to use KingROOT because of the others will not install correct. The others will freezes up my boot screen and causes my phone making noises. The problem with the KingROOT is the su doesn't have all the supports. For example. SD Maid Pro refused to fully clean up my phone.
Also the Apps2SD doesn't support the KingROOT fully. It told me that I need the Chainfire's latest SuperSU in order to move the obb and data over onto the sdcard. SuperSU/SuperSU Pro doesn't even work fully and can't installing the su file.
I think the Dev need to update the su for the T-Mobile SM-G360T with Android 5.1.1 and other phones that have this kind of issue. Maybe have two different downloads just in case one of those doesn't work. Some people had to use the KingROOT and missing out the extra su supports.
Anyway I'm complaining because there is no su fully supports for this version at this time.
Samsung and T-Mobile did a good job on the protections. No telling who all trying to protect their retail phones.
