Root [T-Mobile] Update for Model: SGH-M919 V:4.2.2?
So I found out there was a update for The Samsung Galaxy S4 but I went to update it and it saids "Your device has been modified. Software updates are not available." so i dont know what to do, now i got the infamous #1 ROM
To have any update push you have to pretty much return to stock it won't let you update if you are on a custom rom so best thing is to either do it through Odin or if it become avaliable as a tar to flash it
so you mean, Unroot, be on stock again, UPDATE, then root, and change the ROM again?
There isnt an available update to our M919s... That update came out about 4-5 months ago dude. Every custom rom already has it included, even my rom does.
Really? like since it came out ? because i thought the 4.3 version came out
Nope. No S4, not even the international has gotten TW 4.3.
We all have TW 4.2.2.
Samsung said that they will start rolling out 4.3 TW somewhere in October for the S4 and S3.
As for 4.3 on our S4 there is the Google Edition which is like having a nexus on our S4's.
cause if you look it up you will see theres a update to 4.3
I rather see 4.3 then the app to sd update right now 4.3 has more bug fixes to it plus hopefully the app to sd will be there too
Problem being is that T-Mobile is really bad the release of any sort of updates. I am guessing it will be at least an year before we see 4.3 coming out on a T-Mobile device that is not the Galaxy Note 3.
The sad part is the T-Mobile uses new versions of android on a phone as a selling point/advantage.
