Help T Mobile version location: not working?
hi, so my last one broke and I put ceived a replacement T Mobile version in the mail, and obviously I'd never update to the newest software but this one came with it already installed, and they were something different but the main problem was that before the update and location settings, it has the options GPS satellites or wifi and mobile networks. And this one it has the same options but no app third party or not recognizes or uses location data unless the GPS one is checked even if I set for wifi and mobile network location it won't receive location, and that's annoying because the GPS drans the battery, and also useless because for even something like lost or stolen phone apps even, Android device manager, all someone has to do is turn off the GPS which is easy and you can no longer locate the phone. Even tried other apps like lookout and other third-party location apps and nothing works unless the GPS is enabled. Even a weather app that uses your current location for weather in the status bar doesn't find you with Justf the wifi and mobile network location box checked. This is annoying and I was wondering if there's any way to fix this or anybody else has this problem? Or maybe if anybody knew a way to go back to the previous firmwhere?
