Tab2 Update problems
Julesb
Since receiving the update earlier this week, when trying to download a live stream the internet explorer goes off and the screen goes back to the homepage, or if I do manage to get a stream up there is often no sound. Also Adblock Plus comes up with an configuration error message. Had none of these problems before the update, so any help would be appreciated.
It's more than likely a Flash Player issue. I am unable to play Flash content on my Tab 2 after the update either. Try using Puffin Browser or Flashfox Browser. I hope this helps.
What model and what update?
Flash is no longer natively supported by stock browsers. I dunno about updates after about july as I've been on cm10
I don't remember if I had to uninstall and reinstall Flash after the 4.2.2 update, or if I just left it alone, but it's still working on mine, in the stock browser. Always has.
You must have reinstalled it. Its been a while since I was stock. I believe I went aosp after the jb ota came to america. I'm on a p3113 and had to reinstall a flash player app after that update
