so i was at best buy yesterday looking around for a tablet and i stumbled upon the acer iconia. it is the closest tablet out there to perfection. with its dual core processor and its front and rear facing cameras, its usb and hdmi ports to its 1280/800 resolution. it was a tablet to behold. so then i was doin a little research last night when i got home about the tablet and i stumbled onto another tablet.
the toshiba tablet. its not slated to come out till july.
so heres my dilemma. which one should i get?
i will list out the pros and cons of each tablet. if something isnt listed, assume its the same for both tablets because both tablets are practically twins. They will both be running honeycomb btw.
acer iconia-
pros- uses micro sd card slot, 16gb is $449 ($150 cheaper than the motorola XOOM)
cons- cant be upgraded to 32gb (but theres micro sd, so not a real issue), cant switch out the battery pack
toshiba tablet-
pros- uses SD card (not micro), can switch out the battery pack with ease, can custimize back plate
cons- price- 8gb is $499, 16gb is $499, and 32gb is $549,, doesnt come out till july
any opinion into this dilemma is much appreciated
acer iconia-
toshiba tablet-
