Tablet with a browser problem
m0thm
Hi all,
I just purchased a Tabexpress from Amazon (it's About Tablet identifies itself as a polaris_GT90H-eng) anyhow it is running android version 4.2.2 and has Firmware v2.0.8.
Something has got into the default browser and set the homepage to kszz.com I can change the homepage to google as much as I like but after 1 or two fresh opening of the browser up comes kszz.com i have tried every suggestion I could find on the net (mainly they seem to consist of clear the data and cache or use about:debug and change the browser appearance) nothing has done the trick. I have just got it all set-up the way I would like and would prefer not to factory reset if there is another way around this. Any ideas most welcome
Tim
I also should say it has had AVG pro, AVG Memory & Cache cleaner, New Air Push Detector, Addons Detector, and Malwarebytes Anti-Malware. Run over it and none of them found the problem
I am going to give this a bump... exact same issue here. Trying to set a homepage on these tablets to use for a school and the tablet automatically changes the homepage to kszz or vandroidnews
The seller on Amazon is Goldengulf and the tablet works perfectly other than this issue.
Anyone?
I thought I was the only one I was beginning to go crazy over this I have along with my wife researched this in so many ways and yes my wife has come up with that Google chrome theory a couple of weeks ago however I'm not satisfied at all ..I want to know why and how,, well we can try the redirecting browser theory like for instance what is KSBROWSER ?? ALSO WHO IS CLEAN MASTERS AND WHAT IS THE MOST POPULAR CHINESE TABLET IN THE ORIENT ,EKEN TABLET OF COURSE WHICH IS WHAT YOU HAVE IN YOUR HANDS' NOW THE REST IS PRETTY MUCH ONE IN THE SAME ALL EITHER OWNED BY OR PARTNERED WITH OR HAVE BEEN A SERIOUS THREAT TO ARE SOFTWARE RESEARCH IT YOU WILL SEE I DID I ALSO IT LOOKS LIKE WILL TRY THE CHROME THEORY CANT STAND KSZZ OR VANDROID I HAVE FACTORY RESET AND SAME OUTCOME I HOPE CHROME WORKS GOOD LUCK DONT TAKE MY WORD ALONE RESEARCH IT I GOT GOOD FEEDBACK FROM MALWARETIPS AS SOON AS I ASKED ABOUT KSBROWSER THEY DESCRIBED MY TABLET TRY IT
I have the same problem, remove it with sd maid app control with root permissions, returning factory settings, browser, and deleting the last app that listed mm jp .... I do not remember
