hello i purchased the droid a few weeks ago and i came from the htc touch pro. i use my phone for everything even more than my laptop. i think the droid is an amazing phone and can do some crazy stuff but i am actually concidering taking the phone back because it doesnt do some of the simpelest of tasks i need it to do. number one is smart dial i cant stand that i hace to go through my contacts by flicking or searching to call some one. it is almost as bad as texting while driving. i did download a couple or programs that do this but they are so slow and not great at all. my touch pro had this along with many other phones and i was on a droid eris last night and found that is did both of the features i am looking for. it had a great smart dial program and i loved it. it also did the other task that i dearly need for work. that is attach documents such as work and excel to my emails with in the email program. on th edroid it only allows pictures to be added when you hit that attachment button. with a app downloaded to view my files i was able to long press and send the file to email but only one file per email and this is a complete pain. there are a couple other items that bug me like how slow the satalite gps is in finding the phone sometimes and my htc had a program called quick gps that updated the satalite info anf made hooking up to the gps almot instant. i am sure you are thinking just get the eris but i want to keep the droid mainly because a slide out keyboard is a must. if these programs are on eris and they are running on android which is open programming it should be able to be put on the droid right? you all know this stuff better than i do so i ask you these questions. can you help? Also i heard that the new 2.1 update that is comming out will disable the gps satalite that sounds crazy why would they do that?
