Help Taking a screenshot,
WebKat
Member
I have the Android SDK installed from this: installer_r20-windows.exe
When I follow the instructions on every tutorial I've found, (CMD window, go to tools dir, type ddms...) which used to work on my older version of Android SDK, I now get an error:
"SWT folder 'lib\x86' does not exist.
Please set ANDROID_SWT to point to the folder containing swt.jar for your platform."
Now, swt.jar is in \x86_64
I tried changing that dir to be called x86 but that gave me a series of other errors. I can't find anything called "ANDROID_SWT"... what do I do?
Like I said, I have an app. I have OTHER REASONS for wanting it on my screen. I want to see (I can't remember) if you can see a live picture on the computer screen when it's plugged in like that. If you can, I want to be able to capture video from it. That's 100% the only reason that I want to be able to do this.
On rereading it sounds like I was angry or something because of the caps. I was simply using them as emphasis--there is no emotional anything attached. Just clarifying. Sorry if it came across snippy because of that.
