flairmedk
Member
So I bought a Targus BT Keyboard. Connects to the tablet just fine and first time use (just a quick test run) on docs to go seemed fine. Next time I used it I started getting double to multi letter retypes like rr or oo and so on. It is intermitent and some times I can get a few words typed with no problem. Targus says it's a bad board and I cannot send back to Targus since it was bought on ebay (albeit New in Box). So I was hoping to see if anyone else had a similar problem and / or fix. I have disconnected the pairing to the tablet and re-established. I have removed batteries for a few minutes and changed to new ones. Still no luck. Thanks for any help!
