Task Killer Question
What apps do I put In the Ignore folder, and what apps should I put In the Auto Kill folder?
Thanks
Ignore folder - Apps that you use often but maybe not at that particular moment.
Autokill folder - apps that you never use, but seem to always pop up as running in the background
