Help Tasks and Calendars
Asterdroid
Android Expert
Hey guys. I'm asking this here because I'm not having any luck in the applications forum.
So, here's my issue.
I absolutely love the new calendar widget from LauncherPro Plus, but Astrid doesn't integrate to it. I also looked into GTasks, but since Google is ******ed and doesn't let you see your task calendar as one of the available calendars in the Android calendar, that won't work either.
What I'm looking for is a task list or todo list application that integrates to either the Android calendar, or to the Google Calendar in such a way that the Android calendar can access it. This way I'll be able to use Fede's awesome new widget and I will still be able to see my tasks.
I love Pure Calendar, but the new Calendar widget for LauncherPro Plus is just so slick and fast, I had to make the switch.
Thanks in advance for any assistance.
Astrid allows me to put tasks in my google calendar (if I assign a date to it) and it shows up on the calendar widget on Launcher.
I use Jorte for calendar
Really? That doesn't work for me for some reason.... It only gives me the option to add to the Astrid calendar, not any other calendars.
