Tasks to homescreen??
tymbian
I'm using Jorte as my organizer and wondered if I can place my Tasks etc. on to a spare home-screen? I'm also using the App. Folderorganizer; Do I need to use this to do it or can I do it through Jorte? What other possibilities are there please? ( without me having to re-write my planner if I install another Calendar app. )
Thanks.
it does hsve a Tasks widget but it seems the only sizes i can get run more down the home screen than across thus only showing half the info that I'd like on show. Any ideas?
I use GTasks and Android Agenda Widget.
Android agenda widget is basically a very customisable calendar for your homescreens, but you can also set up a widget linked in to GTasks, which allows you to see the tasks on your homepage. You can customise the size and style of the widget a hell of a lot too, which is nice.
