I know how apple products tend to be proprietory so just curious.I think so but the iPhone will have to be on WiFi I think.
Should be able to use tango on both if skype ends up not being on it...
Im pretty sure my buddy's iphone4(vzw) used tango with my sisters new incredible yesterday. The incredible was on Wifi but the Iphone4 was not. It did give my buddy a messege about a weak connection though.
Skype has video chat for the puters, but the file is 22mb, and probably expands to 35-40Mb's when opened and installed. I don't think the issue with Skype is so much a technical one as it is a size issue. I'm thinking that's the case as they could have worked through a technical issue by now. Would you like a single app to take over 50% of your storage capability before it is installed? I'll bet they dropped the size, but it's still probably 10+ Mb's and Verizon said "no" to that...rightly so.
jailbreak the iphone and install MY 3G app and it makes the believe it on wifi when on 3G so facetime works with 3g that way. BTW i hate the iphone though but it works...
I don't get it. Who cares about 0.04GB program size (i.e. 40Mb's) when you have 8GB of internal memory and 32GB of external (SD card).Skype has video chat for the puters, but the file is 22mb, and probably expands to 35-40Mb's when opened and installed. I don't think the issue with Skype is so much a technical one as it is a size issue. I'm thinking that's the case as they could have worked through a technical issue by now. Would you like a single app to take over 50% of your storage capability before it is installed? I'll bet they dropped the size, but it's still probably 10+ Mb's and Verizon said "no" to that...rightly so.
-Frank
Desktop Skype also allows multiple-party conferencing, file sharing and desktop sharing.
When it was simply an additionally recognized protocol under Fring, it wasn't very bloaty at all.
It was a battery-hog, tho.
My boss was jealously upset when I Fring/Skyped him from my phone for the first time, via 3G - he reported much higher clarity and a better framerate than I'd ever achieved with Skype video on my laptop. So - high quality is indeed possible with just 3G, the Skype protocols and a rocking HTC phone.Yes, my Yahoo! chat worked well on 3G
As for how big an app needs to be - that's kinda like how many notes ought go into a symphony, don't you think? Not really...If you decompile some of the MS apps, there are developer notes throughout the app that just make it bigger and bigger. It's not bloated apps, that's the wrong term I used...It's bloated code. They don't take out the notes for testing when they finish the product.
I have small apps but also plenty of bigger ones - the more a dev binds in, the bigger it's going to be. Gmail, Fring, Elixer, ES Security Manager, Maps, Handcent - all bigger apps in the 9 to 12 MB range. Handcent is 6.65 which is huge in my eyes...I use it, but it's huge.
And if you consider going from 40 MB on a desktop to 10 MB for mobile, that's a pretty decent trimming, just imo. That is 10MB before decompressing and installing...Probably 15-18 minimum after installation.
We all got royally screwed when Fring was denied access to Skype, and with the Skype debacle last December, I've been on the hunt for better - problem is getting everyone to adopt.I'm hunting too...Let me know if you find the Ark.
Adobe Air showed breakthru promise for all sorts of applications, including videochat, but I've yet to see it impact anything. And we know how Abode apps are - the more they grow, the less they seem to do right - again, imo. Exactly...I uninstalled it again, and nothing I have asks for it to be installed again...
For years, Apple desktops used iChat for videoconferencing via the AIM servers - worked better than AIM or Skype video, really top-notch stuff. But they did keep that for the iP4 - no, they just _had_ to promote yet another closed protocol and wall that garden in. Apple...'nuff said...
I'm hoping Google steps up and provides this service soon. That would be easy for all to access and we could trust it to be implemented right for Android.
Skype solves the videochat problem for Verizon users, but that cuts out the rest of us. (And that all came down when everyone was claiming Skype exclusivity for Verizon until people started pointing out the iPhone on ATT had it - next thing, Skype started to look at ways to charge for mobile use, cut off Fring, then decided to not charge, left Fring cut off.)
Meanwhile - ooVoo is what I'm eyeballing - have to, I've been severed from Skype video.![]()
The build issues with Microsoft aren't really at play here - completely different.
My Handcent while running is 12.5 MB....
As I recall, Skype bought Qik - Qik was the first thing I dropped because it was so Mickey Mouse - maybe they'll improve it, but I'm gonna be from Missouri on that one, they'll have to show me.
Discrepancy could be data - I didn't install the font packs.
