Tbolt Rubberized extended case
Pretty happy with this case. It's a hard plastic case with a rubberized coating. $16.99 with free shipping. I also found the best damn screen protectors for this phone cheaper than hell. Pretty nice set up I got going on with my phone. The screen protectors are awesome all the way around, you don't even know you have it on your phone. If you use Swype it's amazing because they are so smooth. You just can't beat these deals here. I looked and looked for a good value on a extended case and screen protectors. I took out the guess work so you wouldn't have to.
HTC Thunderbolt Rubberized Case with Extended Battery Support
Amazon.com: 5x HTC ThunderBolt 4G Droid Incredible HD ADR6400 6400 Premium Clear LCD Screen Protector Cover Guard Shield Flim Kit: Electronics
I bought one of those cases. It fits the phone so tight that the power button gets stuck in.
Are you not having this problem?
I'm sending it back for an exchange. Maybe I got a bad one.
The good thing is they are paying for the return shipping.
On a side note the phone is pretty tough. I have dropped it 3 times on a tile floor. Other than the battery flying out no other damages are visible. (Knocking on wood now)
Gorilla Glass = no screen protector needed/recommended.
That's what I thought until my screen got scratched in my empty soft cotton shorts pocket. Not all Gorilla Glass is the same grade. They make glass for companies and give choices on the quality of grade. Samsung use the best. HTC use the worse. Screen protector highly recommend on the Thunderbolt.
Do you have a source for this? I did some research and cannot find any indication that Corning makes different grades of Gorilla Glass. I also personally doubt that your phone got scratched in an empty soft pocket. It is more reasonable to believe that you scratched it without noticing while not in your pocket, but first discovered some time later while retrieving it from your pocket.
@Yeahha - Could you help out here? I believe you said you had a family member who works for Corning.
