tbolt vs Incrediable 2?
Both are htc devices the only difference that I can see is the TB is large, 4G and bad battery life. I have the incredible 2 and the size and battery life is great and no lag so far.
Excluding the 4G and .3" screen size difference, they're basically the same phone internally. Thunderbolt does come with a larger SD card.
While these phones are very similar technically (aside from 4G) I found the size difference to be significant.
The Inc2 is a much slimmer and lighter device in the hand (and by the measurements too); the TB felt like a brick by comparison. I keep my phone in my front pocket 90% of the time, and the smaller inc2 is better there too.
Even though I'm in an emerging 4G area, I actually chose the Incredible 2 over the TB because of the size/battery issues. Maybe I'll regret that in a year from now, but when it came down to it, I wanted the phone that was pleasant to use and carry over the phone with faster data speeds. My other choice would've been an iPhone4 (I'm upgrading an old 3G), which also lacks 4G, and I ultimately think the Dinc2 is a superior device (we'll see how I handle Android vs. iOS).
