Help Telus Milestone Overheats when Talking
thewerks
I am just wondering if the overheating of the Milestone, up top near the camera, while talking is common amoung all of the Milestones. On a different forum I found many people complaining of the same problem but no one pipped up and said they did not have the issue. I am going to get a replacement phone, but I worry it will just happen again. If there is anyone out there who has not experienced this please let me know so I can have some confidence in getting a replacement or if I should just get a new phone all together. Thanks
How does it affect the phone functionality? When it heats someone stops hearing you or what?
This is just the GSM/ CDMA module that heats while talking/ using Internet and there is nothing wrong with that.
I guess it seems normal that it would heat up a little, but it shouldn't get as hot as it does. And it ONLY happens when I'm talking on the phone. I actually had to remove the phone from my ear it was getting so warm. In terms of functionality, everything still works good, but I'm worried if it keeps up it will not be ok in the future.
