Temp reading ?
mills23
Android Expert
I read somewhere that this phone has a way to read the temp of the air around it? If so why? And why do we not have a app for that? Just curious
It'll never be accurate since you have a little computer running very near to the sensor.... It should always read too high
If you don't know how to check it in S Health
Steps to Check Temperature on Galaxy S4
  • First, you need to click to the “S Health” application that can be seen on the “Home Screen” of your Samsung Galaxy S4.
  • You need to click on the icon that has been given on the left corner on the top of your screen
  • Now you will be on “Health Board” where you need to click on the option “Comfort Level”. This option can be seen under the category of “Surroundings” on this board.
  • Once you have clicked the “Comfort Level”, you will see the option “Humidity and Temperature”. In front of this option there will be a box that needs to be checked out.
Maybe I don't have this phone though so I don't know if that's the cause but I would think Samsung would put it away from the battery, chips and radios though.
Well I checked the temp in health and it's closer. Only 4 degree diff. I'd like to be able to put it in the status bar
Actually it is accurate.You just have to have it out in the open and not hold the phone. When I have it laying around at home it reads what my thermometer reads, but the moment I pick it up to use it the temperature goes up.
So if I nail it to the wall I shall have a slightly inaccurate thermometer that only costs about $600 more than an actual thermometer that reads the temperature accurately :).
I cannot help feeling that having a thermometer in a phone that gets warm in normal use and is normally going to be in the user's pocket next to their warm body is a pretty daft idea.
The phone will take time to come down to the accurate temperature or humidity. Place the phone on a level surface and give it a couple minutes. Mine has been accurate.
