Accessories Tempered glass for Samsung Galaxy s7
lankyrose
I can't seem to find glad protector that curves around to the frame... I bought one that leaves 1/4" gap around the whole thing. Or it is too the edge but has a lip over the tiny curved edge and when I put a case on I get stress breaks all over because the case is pushing the screen upwards... Should I even bother with glass? I have spent about $25 on several bad ones...
Tried about four myself and gave up. Ended up going with the Spigen Curved Crystal HD, it is a film and not glass. Zagg has started selling their Curved Glass recently that sounds like it might be a good one.
I recently purchased the Zagg glass. It was great for about a week then seems to lift all over and dust gets trapped underneath. Seems the worst possible scenario having dusty trapped close to the screen. I've taken it off and have yet to find one that is a perfect fit
I found the feel of the Zagg to be the best yet. Felt just like my s7 and looked great. So the first few days I was almost wrapped with it. Yet from the outset the left side never sat flush. Given how much this screen saver journey has cost me to date I was willing to wear that despite the frustration when using swipe txt ing on that part of the screen. Purchased on eBay $30 and had no return policy. I have the Spigen curved crystal now and although the feel and look is great, the lift on the edges makes it also next to useless. So frustrating that there seems to be none of the perfect fit protectors that you find with every other phone
I used one by Vmax. But the gold colour is a bit tacky. And it doesn't fit the screen perfectly so theres some movement in the corners. But it's usable and does the job of protecting the screen.
I got mine done at those kiosk at mall for my s7.
I think its one of those chinese ones. Seems ok to me. Should I be worried? Cuz there are some $25+ temper glass.
Finally found one that fits and feels good to touch. Spigen curved crystal case friendly. I had to go through 3 of them to get it to stick properly on the edges, the company just replaced the first two. But......it's not glass and yet I'm really happy with the fit and feel
I have bought 2 from eBay and they've both been rubbish. I'm wondering if it's just the ones I bought or is it because of the edge. Had 1 on my s4 for 2 yrs never a problem. Very strange
