Root tempmonitor froyo
iamloco724
any word on when we will be able to see cpu temps in froyo i like monitoring this not just by touch but by actual numbers
I've downloaded OS monitor from the market, and it's giving me a number that it says is the temp for the battery and cpu (2 separate values). Are these numbers not accurate/correct on Froyo? I just rooted/upgraded mine last week and downloaded OS monitor the day i upgraded.
Some of p3droid's kernels are partially reporting temperatures, however, while these are actual cpu snapshots, they tend to freeze at some temp and fail to update. This is a problem with the cpu temp mods themselves, and has nothing to do with the stability of the kernel. I am in contact with p3 and other devs and all are aware of the problem.
Setcpu also shows a temp, but again, fails to update for the same reason. If you watch the reported temp over the course of a day you will see what I mean. Tempmonitor will show the same data in these cases, but again, note that the reading is not updating correctly. This has nothing to do with the apps themselves. A correct temp reading should fluctuate fairly quickly.
At times, you may notice that after a reboot you will see a -40 reported for cpu temp from other apps, while tempmonitor cancels its notification and does not show data... this is due to a catch I've added to tempmonitor that helps to prevent invalid data from from being displayed.
Just wanted to note how much I like your app...one of very few that are musts for any droid I use. Nice work. :)
Just an update :)
P3droid will be dropping froyo kernels with functioning temp tonight!
Tempmonitor 3.0 will push some time saturday... Including widgets.
Hooray! Been waiting for this for a while. It's always nerve wracking to be playing a flash game and feeling the Droid heat up but not really know how hot it's getting.
So is this code public so other kernel devs can implement? I tried to send you a msg several times but for some reason it never took ... hopefully you didn't receive all of them!
Absolutely chevy.. It's source now not later :)
Feel free to hit up myself or p3... pls find my email on the tm market app screen.
P3 also had the driver in his github account.
All that failing you can find it on my home server:
Index of /files/omap
Downloaded and re-flashed P3's LV 125-1100 kernel. I installed temp monitor, but it keeps telling me its "Showing system stored data, waiting for real-time data." Also, i'm still only showing the battery temp. Any suggestions? This is the full $1.99 version btw.
