Temporary Battery Life Solution
john0821
I turned this thread into my little DX journal ...
Bugs, Issues, Troubleshooting
Droid X manual - download here
Battery - My battery life is awesome now. I went to the main Settings > Battery Manager > Battery Profile > Smart Mode. After setting it to Smart Mode, I opened every app and adjusted its settings/preferences. I set everything to manual refresh/update. The only apps set to hourly updates are e-mail, weather, and sports ticker. Also, setting the screen brightness level to less than 50% helps. Another tip is to avoid using live wallpapers.
Advanced Task Killer - I can understand why some believe this is a useless app. In a perfect Andriod world without buggy apps, ATK would be unnecessary. However, it is easy to use when you do need for force kill a problematic app. As long as you go to Settings > Auto Kill Level > Disable, this sets it to manual mode instead of ATK autokilling apps. Set your ATK to ignore apps that you do not want to kill. If your cellphone is lagging, kill everything except what's on the ignore list. If you know which app is causing the lag, you can just select that app to be killed.
Signal Bug - I recently had signal issues with my DX where every hour, or so it seemed, the phone would vocally notify me with, "signal lost ... Verizon wireless." Visually, the signal bar would switch back and forth between 3G and 1X with the bars fluctuating from full to none. Dialing *228, prompt 2 has seemed to addressed the signal issues and returned the phone back to having excellent battery life. By doing this, it updates the PRL (preferred roaming list) which is the list of towers your phone uses. *22899 can be used to re-program your data connection.
Notable Apps
chart
Fancy Widget - SenseUI style clock/weather widget
Easy Root
1 click Root - This is the compatibility test, but it leads to the (now removed) Easy Root app.
Icons
LauncherPro Icons
DX Dock - credit Prophecy23
DX Eye - credit Prophecy23
little green android icons
red/black glossy icons #1
red/black glossy icons #2
red/black glossy icons #3
red/black glossy icons #4
Orb Glared
Orb Non Glared
Glass Orb
tons of free custom icons
Wallpapers
Flikie Wallpapers HD
Golden Gate Bridge
Asian Landscape
Swirl
Black & White Model Design
Pattern
Super Mario
3D Mushrooms
Smurf House
San Francisco Giants
San Francisco 49ers
Los Angeles Lakers
