bobarr
When I turn my incD off overnight and start up the next day, often a lot of the apps are missing!!
Some type of 're-syncing' takes place and the apps return. Sometimes it takes quite a while.
Anyone have the same problem?
I'm wondering if I turn it on in a non-service & non-wi-fi area if the syncing will take place and return the apps?
Or is the incD just re-loading info from the SD card since most of my apps are there?
My solution- I loaded SilentSleep that turns things off at nite, leave the incD on, and all is well.
Bo
Bo
