Ten questions about Android and Samsung S2
umby75
) Why when I launch an file* the android system asks me which app it must use for the opening of the launched file (obviously I check the box control to open always through that app!)?
2)* I changed the lockscreen of my Samsung stock ROM (2.3.6) through the Magiclocker app. But since I installed this lockscreen the loading of launcher is more low than before of the Magiclocker installing.
Why?
How can I do to have a loading more fast?
Am I forced to change the Rom and to make a root?
3) When I check the 3G traffic (up/down) through Phoneusage app I find much quantity of traffic
caused by Bookmarks to Sd app? Who is does know the reason? What is this app and why it has needed of 3G traffic?
4) Why even if I checked the box to "launch automatically Skype" at startup it hasn't* loaded?
5) Sometimes when I use Dolphin browser this program closes* itself suddenly (it happens even only with one opened window!). Why?
6)* The working temperatures when I browse on internet with recharge unplugged are about 40 degrees Centigrade. When I plugged the recharge the temperature goes up 50 degrees. Is it a normal working considering the plastic materials through which the smartphone was built?
7)* What is the difference between internal device memory and the Ram?
Which is the function for each?
8) In Skype does exist an expedient to play the speaker at the front of S2 over or instead to play the only rear-down default speaker?
9) I restored by backup olds setting and apps of my last htc desire hd. After the restoring I found into apps section of S2 two separete groups of apps: first the Samsung's S2 default apps and then my apps restored...
Can I show their promiscuous?
10) Can I change the Vlingo app when I push double touch on central key?
Thank you in advance for your replies!!
Inviato dal mio GT-I9100 usando Tapatalk
