Root terminal emulator ?????
mbancroft
Originally Posted by mbancroft
can this process also be used to flash custom splash screen???
"1) Verify you don't already have flash_image (open terminal and type "which flash_image". If it just says not found, you need to flash it. If it gives you a location (most likely /system/bin/flash_image) your ROM already has this, and you can skip to step 4.
2) Flash flash_image-signed.zip from recovery.
3) Reboot normally when done.
4) Extract recovery.img from the PC36IMG.zip for the recovery you want
5) Copy recovery.img to the root of your sdcard
6) From the terminal type:
su
flash_image recovery /sdcard/recovery.img"
and also would I change the wording to something else I.E. "flash_image (splash screen)(instead of recovery) /sdcard/
following to same logic instead of recovery would I type in "evosplash1":
