Root Terrible Issue
pmb116
So today I notice that I have a voicemail. Call my voicemail and apparently had 14 messages. WTF? I think. I've had no missed calls and my phone hasn't rang. So I try to call my phone from a land line and sure enough my phone doesn't ring and the caller I'd doesn't light up. So I try to send a text. Hangs on sending for 10 plus minutes. Usually if it doesn't send because of shitty metro it kicks it back within 30 seconds. So next I tried data over 3g and that worked fine. So I tried to call a few numbers and the calls went through. I tried dialing *228 and updating the prl and it was unsuccessful. I then went back to a nandroid from a fresh install. Still same problems. Called *611 and basically they refreshed the phone and now I can rarely get a text out, not receive them,make calls not receive and have full access for data and apparently after checking with my wife's texts and calls to me its been out for 3 days. Any suggestions?
By the way Im on Bobs 2-21 CM7 and CWM recovery have never had an issue till the past couple days
what PRL are you on? also make sure you are on CDMA/EvDO if you use EvDO only and have signal it won't receive calls, I've had that experience before..
So on a hunch I toggled to EVDO then back to CDMA/EVDO and rebooted and everything works fine now. Really odd.
