If you're one of the lucky folks who has a Samsung Galaxy (also known as the Vibrant or Captivate, depending on your carrier), you may have noticed a problem with GPS either taking a long time to resolve your position (or not at all), or your location being "way off." Lucky for your, the uber-geeks over at XDA-Developers cooked up a way to quickly and easily fix the problem!
This fix won't require any flashing of files, unlocking of bootloaders, or anything that could void your warranty, and reportedly Samsung is aware of the issue and is working on an "official" fix that shouldn't have any problems with this work-around.
To apply the work-around, follow these steps:
1. Navigate to Settings > Location & Security and uncheck the box next to "Use Wireless Networks".
2. Go to the phone's dialer and enter the number *#*#1472365#*#* then press send to access the phones LBSTestMode menu.
3. In the LBSTestMode menu, press
