Boraichee
this rom is a tester rom its not done but i told you guys id let you try it. more info in a bit.
NO NOOBS this rom is ext4 900mhz
Based on ctmod for the preveil. Also im going to be post a straight ctmod port.
things too still work on
theme is not finished
id like to get the kernel mods to work for are devices (new kernel?)
need to remove download mode from power menu
need too fix gps/mms (easy fix)
still working on porting my ics settings for the admire.
borai mod alpha v.1 http://d-h.st/OCM
thanks to blooddawn for his ctmod
thanks to spz0
THIS ROM IS ONLY HERE FOR TESTING. PLEASE I DONT WANT POSTS ABOUT THINGS NOT WORKING INLESS YOU ARE TRYING TO DO SO IN HOPES OF POINTING OUT THE PROBLEM SO THAT I CAN FIX IT. THIS ROM IS NOT A DAILY DRIVER. IT IS NOT FINISHED.KEEP THIS IN MIND WHEN FLASHING!!
thanks to spz0
But Why Is It That I Get The 492 Error Everytime In The Play Store?
i think i might be falling into insanity
