I have been testing Miui 2.10.12 and here are some of my impressions.
Positives:
- Jellybean 4.1.2
- No bloat, a 156MB zip file + 5MB update zip
- Built in CPU under-clocking utility
- Long pressing home key brings recent app killer; tells amount of memory freed
- There is an app permission log that tells each permission a user installed app has and also what apps use each permission. E.g. 1 app can access your contacts and which app.
- Built in virus scanner
- Manager for user installed apps that autostart
- Status bar has all toggles and customizable
- Many customization options and easy to download and install themes
- WiMax and mms/sms work
- Both Speedtest.net and Antutu are comparable to CM10 and other ROMs
Negatives:
- No app drawer: Home screen + left are your managed screens, flipping right shows most apps (not all preinstalled; e.g. keyboard voice recognition)
- Drains battery quicker than some ROMs
- Having some issues with some apps. Google voice recognition for typing is not working for me and with no app drawer, can’t ‘force’ it.
- Some utilities can use ext-SD and some can’t.
I see Miui 2.10.12 as being a slight battery hog but might be well worth it with some of the added security and other features.
Positives:
- Jellybean 4.1.2
Negatives:
