Tether 4g blocking bypass
Nintendo1889
I have a solution for bypassing metropcs hotspot/tether blocking/deep packet inspection but I prefer not to post publicly so they will not try to block it. Please pm me if interested.
If there's no danger in metro trying to block it, then I'll post it. It involves proxying.
Hi I was interested in your fix for the tething on my motion because for some reason after I had to do a factory reset I am not able to use it any more it worked before I reset it but thanks for help if you can
There's no danger posting here. It took metro quite a while to block tethering in the first place.
Please let me know how overpass metro pcs hotspot . Appreciate thanks :)
Please give me your secret. Thanks
Is that what i need to allow my pc tp use internet? If so send to me, please!
Can you give me a hand. I'm trying to figure this out. Stuck.. Thanks.
Helpp
Hi, are you familiar with the ZTE ZMax?
Hello Mr Nintendo, I'm having the same problem and I need help with that answer. I just upgraded to the $60 plan with Metro and I also have the FoxFi however, it's using my hotspot data and now I'm already almost maxed out of my hotspot data. Please help. Thanks in advance.
