Root Tether LG esteem to Roku media player
If you could set the phone up as hotspot, that it should work unless the carrier blocks the traffic somehow. But, in theory, it should work and technically it can work. I've never tried it, I just route the box through my router.
Yes I have. Just make sure your user agent in wireless teather is the optimus s. Should work like a charm. Its a little slow compared to my 30meg cable tho. :)
Okay you need to download the wifi tether with the yellow wifi icon the one that most roms come with then you have to go to settings and change the device profile to LG optimus S and change the setup method to softtap and check the wifi driver reload then try to connect the media player it should work.... cuhs the main problem with these types of players is that they won't connect to adhoc wifi which is what most tethering apps do they setup adhoc networks but this workaround makes a real hotspot/acesspoint
