tether only local connection!
Had it working long enough to sign up Netflix then No pages would load and it said CNS Error .... I have No clue what to do any ideas? Thanks!
I moved your last thread to the ZTE Warp All Things Root forum, please check that section for more specific support on your device and help with your issues.
In addition if you are trying to use a non ad-hoc wifi tether then it wont work, Barnacle wifi tether works on the warp as far as i know. you can download it from google play
