Help Tether Rezound to Nexus 7 - Did anyone get it to work?
rootbrain
Downloaded several tether apps to my Rezound, get the wifi tether app open and working, but my Nexus 7 never sees it.
Did anyone get this to work? Rooted, custom ROM and Amon Ra recovery.
It works just fine for me. Is it only your tablet not seeing your WiFi or everything?
Using WiFi Tether you have to do the following:
  • Start Application
  • Go to Settings
  • Select Device Type -> Galaxy Nexus LTE
  • Select Change Setup-Method -> netd (master)
  • Select Enable WiFi-Encryption -> Your Choice
  • Select Routing Fix
  • Start Tether and allow Root
  • Start Application
  • Go to Settings
Latest WiFi Tether has a Rezound profile...
