Help tethering please help me?
ctxx24
ok i understand basically i can do this at home instead of paying for my isp....but if 20 only gets you 2mb y would you do it?
It's 2GB. I assume many people use it while traveling. It isn't mean to be a home broadband replacement.
Even just using Tethering while traveling...probably wouldn't even be enough. Honestly I would burn through 2GB within an hour.
Honestly you wouldn't come close in an hour. 2 gig is about 2 billion bytes, which is about 20 billion bits and your connection speed is what? 2 million bits per second max. So 10 thousand seconds of use is 27 hours continuous max download.:D
