Help Text issues
Are they just not there at all or you cannot display them in the gallery? I do know if you're using Google voice for texting you cannot send or receive pictures.
As weird as this sounds, sometimes installing the Verizon Messages app fixes these problems. I think that once the issue clears up (if it clears up using this app) you can then uninstall it and things remain fine.
https://play.google.com/store/apps/...DEsImNvbS52ZXJpem9uLm1lc3NhZ2luZy52em1zZ3MiXQ..
One obvious thing to check, though, is settings->Battery & Data Manager->Data delivery and make sure that Data Enabled is checked. MMS messages are delivered using the data network (3G or LTE) and I believe cannot be delivered if you have data disabled. (If you have data enabled but are using WiFi that's ok, as the phone will use LTE or CDMA to deliver the message and the media.)
